*AVOID Acaster Malbis*
Moderator: Moderators
The council have 'resurfaced' the roads through the village by throwing down a load of tar and sprinkling a few chippings on top. I got about 100 metres along it when my wheels locked up due to tar and stone jammed in my frame and stuck to my tyres. I then had no choice but to carry my bike back to the good bit of road which clogged up my cleats. This meant spending half an hour at the side of the road in the rain with a small knife trying to clean my cleats and bike up. I was so mad i could have picked up my bike and thrown it over the hedge.
What the hell is the point in doing this? The roads were much better before. Is there someone reading this that works for the council/highways that can explain such atrocious quality of work? They have done the same in Bilbrough which is making these 2 places impossible to ride through. Anyone else had the same experience?
Most of the roads around there are being resurfaced at the moment but the few I use to get to my horse are usually done better than that. So I would avoid Acaster Malbis generally for the time being but the works are meant to be finished soon I think anyway. As for the newbie chaingang route I haven't noticed any roadworks happening apart from a bit in Appleton Roebuck where they are finishing housing.
I think the council are on a mission to destroy all roads around here
The route I go to york, naburn way is getting chippin crap on it now, means I have to go to the transmitter near stillingfleet and get on the cycle track, no doube the whole part up to naburn will be done too, even the roads around my village, the back roads I used as a quick 3 mile circuit are now covered in this crap, allthough its abit more compact but its messing up the paintwork
So is the actual into chaingang circuit up at acaster also resurfaced? Was going to use that more often.. shame
BroomWagon
BroomWagon
I believe - though might be wrong - that concrete is much more expensive than normal tarmac and it takes longer to build the road, but it does last longer.
They've resurfaced my parents road on Woodthorpe in a way that is supposed to be even cheaper than chippings....and it's awful, though at least you don't get hit by flying stones.
Trouble is, concrete has to be laid in sections and, like railway track, needs an expansion joint in between each bit so that it doesn't distort in really hot weather (tarmac doesn't need this as it just softens in the heat to take up the expansion), therefore every so often you get a significant gap where the joint is and a very noticeable 'bump', even in a motor vehicle with suspension. Anyone with the misfortune to have travelled on a concrete motorway at speed (the old M54 surface through Telford was a real shocker) will know what I mean.cath wrote:I believe - though might be wrong - that concrete is much more expensive than normal tarmac and it takes longer to build the road, but it does last longer.
Dave
